Ir para o conteúdo principal
Samsung Galaxy Sol Speaker Replacement
O que você precisa
  1. Samsung Galaxy Sol Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back case of the phone by using an opening tool or fingernail to lift the divot on the top left side.
  2. Samsung Galaxy Sol Speaker Replacement: passo 2, imagem 1 %32
    • Remove the battery by lifting from the bottom up with an opening tool or a small flat tool such as a credit card.
  3. Samsung Galaxy Sol Speaker Replacement, Speaker: passo 3, imagem 1 %32
    • Remove all ten 0.4mm screws by unscrewing them with the Phillips #00 screwdriver. After this, you will be able to lift up and remove the grey plastic piece.
  4. Samsung Galaxy Sol Speaker Replacement: passo 4, imagem 1 %32
    • This is the speaker that you will be removing in the next step.
  5. Samsung Galaxy Sol Speaker Replacement: passo 5, imagem 1 %32
    • Using the curved tweezers, grab ahold of the gold piece of the speakers and slowly lift out of the speaker slot.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 387
