Ir para o conteúdo principal
Samsung Galaxy SIII Mini VE Battery Replacement
O que você precisa
  1. Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, imagem 1 %32 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, imagem 2 %32 Samsung Galaxy SIII Mini VE Battery Replacement, Removing Rear Casing: passo 1, imagem 3 %32
    • Flip the phone over so you are viewing the back.
    • Using you fingernail, or an opening tool, pry open the notch that is located at the top of the phone.
    • Carefully follow you finger or opening tool around the edge of the rear casing until it has detached from the phone.
    • Set the rear casing aside for future use.
  2. Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: passo 2, imagem 1 %32 Samsung Galaxy SIII Mini VE Battery Replacement, Removing the Battery: passo 2, imagem 2 %32
    • The battery is the large grey and black rectangle.
    • Using your fingernail, or opening tool, gently pry the bottom of the battery until it pops out.
    • Place the old battery aside for now, or dispose of it properly.
  3. Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: passo 3, imagem 1 %32 Samsung Galaxy SIII Mini VE Battery Replacement, Inserting New Battery: passo 3, imagem 2 %32
    • Locate your new battery.
    • Correctly orient the new battery to be inserted.
    • To orient the battery, make sure the 3 metallic bars align with the 3 prongs on the phone.
    • Gently insert the new battery into the battery slot.
Conclusão
9 outras pessoas executaram este guia.
Megan
Membro desde: 10/23/14
1.186 Reputação
Autoria de 6 guias
Equipe
Michigan Tech, Team 1-8, Lauer Fall 2014 Membro de Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 3,322
