Ir para o conteúdo principal
Samsung Galaxy SIII Mini Display Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32
    • LCD Display + Touch screen (Display Assemblay) for Samsung Galaxy S III mini / i8190.
    • Switch off the phone, remove the battery and any SIM and memory card.
  2. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 2, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 2, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 2, imagem 3 %32
    • Remove 10x Phillips screws.
    • With a plastic tool remove the Middle frame.
  3. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 3, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 3, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 3, imagem 3 %32
    • Disconnect:
    • Menu buttons flex cable
    • Micro SD Card reader flex cable
    • Lift up slightly the mother board from the right edge.
    • Unstick the Earpiece and Main camera from the display frame. Be careful, don't break flex cables.
    • Now disconnect the LCD Display flex cable which is located on the underside of the board.
  4. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 4, imagem 1 %32
    • Front camera
    • Main / Rear camera
    • Earpiece
    • Loudspeaker
    • Vibro motor
  5. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 5, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 5, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 5, imagem 3 %32
    • Let's test the new spare part.
    • First connect the Display assembly, grab the phone comfortably and then put the battery.
  6. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 6, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 6, imagem 3 %32
    • Warm the touchscreen to make adhesive tape soft. You can use a hair dryer.
    • If the glass is cracked, put the tape in order not to scatter pieces.
    • Use the front camera hole to separate the glass at the corner.
    • Continue with separation with plastic tools, from up to down.
  7. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 7, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 7, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 7, imagem 3 %32
    • Gently separate the menu buttons flex cable from the touchscreen.
  8. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 8, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 8, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 8, imagem 3 %32
    • If the display is left on the frame, use the same techniques to remove it.
  9. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 9, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 9, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 9, imagem 3 %32
    • Clean the frame from the remnants of tape and install new.
    • Be careful with the menu buttons and the holes for the camera and the light sensor, don't cover them.
  10. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 10, imagem 1 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 10, imagem 2 %32 Samsung Galaxy SIII Mini Display Assembly Replacement: passo 10, imagem 3 %32
    • Will be easier if you use adhesive, ready for the model.
    • Install the new display assembly and start with reassembling.
  11. Samsung Galaxy SIII Mini Display Assembly Replacement: passo 11, imagem 1 %32
    • That's all.
    • Did you do it successfully?
Conclusão
18 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
2 comentários
Followed the VDO exactly and managed to fix the screen. Getting the right glue for the screen delivered took the longest time.
Erick Ogam - Responder
Worked perfectly, used regular glue I had at home and it worked just fine. Thanks!!
Elisa Díaz Ipes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 17,497
