Introdução
Replace the USB-C Charging Port (Daughterboard) in your Samsung Galaxy S9+.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
5 outras pessoas executaram este guia.
2 comentários
Hi..good morning.. I have this problem..they replaced my charging board with a new one because its not charging, and its charging again…the problem is…after they do the replacement..now the signal/network connection is gone. I’ve already did a factory reset hoping that its a software problem..but its still the same….the technician here said he dont know how tp fix this..hopefully you guys can help me with this
ys_hotel - Responder
Sounds like something did not get plugged back in correctly after they replaced the daughter. Make sure and double check all connections I. The same order the video shows.
Mikeo52 -
