Introdução
Use this guide to remove the NFC antenna and the charging coil of the Samsung Galaxy S9.
Opening the Samsung Galaxy S9 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally, but will lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before you begin, switch off your phone.
Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
Press a suction cup onto the back cover.
Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
Insert an opening pick in the gap you created and slide it to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Insert a third opening pick to prevent the adhesive from resealing during the rest of the removal procedure.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
After you've completed the repair, follow this guide to test your repair.
3 outras pessoas executaram este guia.
