Ir para o conteúdo principal
Samsung Galaxy S8 Plus SIM Card or SD Card Replacement
O que você precisa
  1. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: passo 1, imagem 1 %32 Samsung Galaxy S8 Plus SIM Card or SD Card Replacement, SIM Card or SD Card: passo 1, imagem 2 %32
    • The SIM card tray's ejection hole looks almost exactly like the microphone hole, located just a short distance away. Insert your tool only where indicated. Inserting your tool into the microphone hole may result in permanent microphone damage.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, on the top edge of the phone.
    • Press firmly to eject the tray.
  2. Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: passo 2, imagem 1 %32 Samsung Galaxy S8 Plus SIM Card or SD Card Replacement: passo 2, imagem 2 %32
    • Grab the tray and pull straight out to remove it.
    • SIM and/or SD cards will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket near the outer end of the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket to protect your phone's internal components.
Conclusão
After you've completed the repair, follow this guide to test your repair.
5 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
427.118 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 16.573 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 33
Últimos 30 dias: 168
Duração total: 17,594
