Ir para o conteúdo principal
Samsung Galaxy S8 Plus Motherboard Replacement
O que você precisa
    • Step by step tutorial about dismantling the logic board from Galaxy S8+. If you need more information ask them in the comments!
    Can you give contact number
    Sandeep - Responder
Conclusão
6 outras pessoas executaram este guia.
Alex Sander
Membro desde: 02/28/17
38.219 Reputação
Autoria de 202 guias
3 comentários
How do you then fix the imei to match the back of the phone and to work with the plan it was on when broken; having to register/activate a new device for a motherboard repair is bull$][!+, and doesn't take care of the problem for the customer.
chrisjwellnitz - Responder
Hello, The connector from the battery to the motherboard has been damaged. Due to water getting in there’s been corrosion on the connectors which has eaten away on 2 of the capacitors there down to the silicon. Is there anyway to fix this? Perhaps any way to add material back or make some kind of jumper? I doubt I can get a replacement motherboard, but if you know if this can be done that would be great.
Ggarcia - Responder
..does this correct a problem with the SIM card holder or is that a separate board in the phone?
Sigmund -
Sigmund - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 17
Últimos 30 dias: 52
Duração total: 10,904
