Ir para o conteúdo principal
Samsung Galaxy S8 Plus Display Assembly (With Frame) Replacement
O que você precisa
Instruções em vídeo
Conclusão
33 outras pessoas executaram este guia.
Jeff Suovanen
Membro desde: 08/06/13
427.862 Reputação
Autoria de 259 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.734 guias
5 comentários
something to note, not sure if the guy mentions in video (it’s german, I didn't actually watch it) :
If you try and test the new display before you reassembled the mid frame, you will get a temperature warning. reinstall all screws and mid frame then test, should be good.
also, this is the only method you should attempt this repair, as the official samsung screens will come like this, with frame. If not, its not original, don’t waste your time or money on sh!tty parts
Andrew - Responder
Agreed! I love my OEM Samsung Service Box Display
Ethan Bain - Responder
Best video I’ve seen of the S8 teardown. Agree with what Andrew said above, check the midframe to see all the extra small parts are there. To check everything works, you can turn on the phone with after connecting the display to the motherboard, and puting the internals back together (everything but gluing the front and back pieces). Be careful to put all the screws back in place- the motherboard needs a tight connection to components on the midframe (like the power button and audio speaker) to work. Good luck!
Michael M - Responder
Can I buy the screen replacement
Christian lares - Responder
How can i by samsung Galaxy 8+ screen?
Nguse Hayelom - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 71
Duração total: 31,103
