Ir para o conteúdo principal
Samsung Galaxy S8 Active I/O Daughterboard Replacement
O que você precisa
  1. Samsung Galaxy S8 Active I/O Daughterboard Replacement, SIM Tray/Card: passo 1, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, SIM Tray/Card: passo 1, imagem 2 %32
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Samsung Galaxy S8 Active I/O Daughterboard Replacement, NFC Antenna and Charging Coil Assembly: passo 2, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, NFC Antenna and Charging Coil Assembly: passo 2, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, NFC Antenna and Charging Coil Assembly: passo 2, imagem 3 %32
    • Removing the back cover of the S8 Active will compromise its waterproof seals. Have replacement adhesive on hand before you proceed, or be sure to avoid exposure to liquid if you do not replace the adhesive when you reassemble the device.
    • Remove four black 3mm screws from the outside edges of the device that hold the rubber bumpers in place using the TR6 Torx Security Screwdriver.
    • Take off the rubber bumpers from the top and bottom edges of the device.
  3. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 3, imagem 1 %32
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
  4. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 4, imagem 3 %32
    • Insert the Jimmy tool under the edge of the back cover.
    • Because of the texture of the back cover, a suction handle does not provide any grip to help lift the back cover.
    • Once the Jimmy tool is under the edge of the cover, insert an opening pick into the seam to prevent the seam from closing if the Jimmy tool slips or is accidentally removed.
    • Cut slowly around the top section of the device and be careful to avoid damaging the cables for the fingerprint sensor and camera. Avoid prying too far into the top of the device to protect the fingerprint sensor.
    • Slide the Jimmy tool down the sides of the device, separating the adhesive.
  5. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 5, imagem 1 %32
    • Use the opening pick to slice through any remaining adhesive.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
    • Open the back cover slightly to the point that you can see the fingerprint sensor flex cable connector.
    • The fingerprint sensor cable connects towards the top of the phone near the front-facing camera. To avoid tearing the cable, pull the back cover off gently.
  6. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 6, imagem 2 %32
    • Slowly flip the cover over and set it down on top of the rest of the device.
    • Disconnect the fingerprint flex cable using the flat end of a spudger.
    • Remove the back cover.
    • To reconnect the fingerprint sensor cable during reassembly, angle the back cover until the flex cable lines up over its socket. Use the flat end of a spudger to snap the cable in place by gently pressing straight down.
  7. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 7, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 7, imagem 3 %32
    • Remove eleven 3.5 mm screws using a Phillips #00 Screwdriver.
    • Remove two 2mm screws using a Phillips #00 Screwdriver.
  8. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 8, imagem 2 %32
    • Remove the NFC antenna and charging coil assembly using the flat end of a spudger.
  9. Samsung Galaxy S8 Active I/O Daughterboard Replacement, Loudspeaker Assembly: passo 9, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Loudspeaker Assembly: passo 9, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Loudspeaker Assembly: passo 9, imagem 3 %32
    • Remove the loudspeaker assembly using the flat end of a spudger.
  10. Samsung Galaxy S8 Active I/O Daughterboard Replacement, Headphone Jack: passo 10, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Headphone Jack: passo 10, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Headphone Jack: passo 10, imagem 3 %32
    • Remove one 3.5 mm screw using a Phillips #00 screwdriver.
  11. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 11, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 11, imagem 2 %32
    • Disconnect the headphone jack flex cable using the flat end of a spudger.
  12. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 12, imagem 1 %32
    • Insert the Phillips #00 Screwdriver into the headphone jack located on the bottom edge of the device.
    • Gently push the screwdriver upwards, ejecting the headphone jack.
  13. Samsung Galaxy S8 Active I/O Daughterboard Replacement, Motherboard: passo 13, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Motherboard: passo 13, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, Motherboard: passo 13, imagem 3 %32
    • Disconnect the battery flex cable using the flat end of a spudger.
  14. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 14, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 14, imagem 2 %32
    • Remove one 3.5 mm screw using a Phillips #00 Screwdriver.
  15. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 15, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 15, imagem 2 %32
    • Disconnect the Volume Up, Volume Down, and Bixby button flex cable using the flat end of a spudger.
  16. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 16, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 16, imagem 2 %32
    • Disconnect the display flex cable using the flat end of a spudger.
  17. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 17, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 17, imagem 2 %32
    • Disconnect the charging port flex cable using the flat end of a spudger.
  18. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 18, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 18, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 18, imagem 3 %32
    • Disconnect the black and white antenna cables using the flat end of a spudger.
  19. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 19, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 19, imagem 2 %32
    • The motherboard rests on top of the daughterboard, and there is a flex cable connecting them. Disconnect the flex cable that connects the motherboard to the daughterboard using the flat end of a spudger.
  20. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 20, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 20, imagem 2 %32
    • Position the flat end of a spudger at the top edge of the motherboard.
    • Carefully pry up and remove the motherboard.
  21. Samsung Galaxy S8 Active I/O Daughterboard Replacement, I/O Daughterboard: passo 21, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, I/O Daughterboard: passo 21, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement, I/O Daughterboard: passo 21, imagem 3 %32
    • Remove five 3.5 mm screws using a Philips #00 screwdriver.
  22. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 22, imagem 1 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 22, imagem 2 %32 Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 22, imagem 3 %32
    • Disconnect the black and white cellular antennas using the flat end of a spudger.
  23. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 23, imagem 1 %32
    • Detach the flex cable that connects the charging port to the motherboard using the flat end of a spudger.
    • The flex cable is lightly glued to the device's frame with a small bit of adhesive.
  24. Samsung Galaxy S8 Active I/O Daughterboard Replacement: passo 24, imagem 1 %32
    • Starting from the middle of the I/O daughterboard, carefully lift the daughterboard up using the flat end of a spudger.
    • Remove the I/O daughterboard.
Conclusão
4 outras pessoas executaram este guia.
Sarah
Membro desde: 01/24/19
413 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S2-G1, White Winter 2019 Membro de Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
Membros da 3
Autoria de 11 guias
Um comentário
Thanks for writing this guide! It let me fix my phone successfully :)
Here are a few tips for anyone else trying to follow this guide:
- The screw sizes (3.5mm vs 2mm) are off. All the earlier screws are 3.5mm, and all the later ones are 2mm
- It’s a bit risky, buy you may need to gently use something sharp to cut away the back cover. I very carefully used an exacto knife, only cutting in a few millimeters to get it started. Then I switched to a putty knife.
- Connect the motherboard and the IO daughterboard before inserting them back into the phone.
- The black and white antenna cables must be placed very particularly to allow the loudspeaker to fit. Route them through the small notch in the motherboard, which you must do before putting the motherboard back in.
- Make sure the loudspeaker assembly, NFC and charging coil are flush with the back cover when you insert them. This requires aligning the tabs at the edges underneath the adhesive. This is important if you want the back cover to fit properly.
Benjamin Hannel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Duração total: 3,264
