Ir para o conteúdo principal
Samsung Galaxy S7 Rear Camera Lens Replacement
O que você precisa
    • Follow this procedure if you are replacing only the glass lens over the rear-facing camera.
    • If you are replacing the entire bezel, skip this step and follow the instructions in the next step.
    • Follow this longer procedure to replace the bezel and camera lens, which are installed on the rear case.
    • If you follow this procedure, you will need new adhesive to reinstall the rear case. Follow this guide to reinstall the camera bezel adhesive as well as the rear cover adhesive.
Linha de Chegada
33 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
223.466 Reputação
Autoria de 168 guias
12 comentários
THANK YOU SO MUCH for the first video!!!
Grace Arnott - Responder
Follow up... What happens if there is a bit of dust? Is there a way to get rid of it?
I ordered 2 lens replacements and neither one of the lenses have adhesive on either side do I need to buy some kind of adhesive sepratly or should 1 or these sides already have it on there
Joshua albano - Responder
same thing with mine josh albano i just plopped it in and am going to hope for the best.
John Biello - Responder
How can I make sure I don't get my replacement glass in backward.....because my focus is still gone. I'm devastated because I purchased this phone specifically for the camera to take pictures to upload to my eBay account. I worked for almost a full year before I could afford to buy this camera phone and I purchased it outright from straight talk. I own my camera and it is not insured. I followed your directions to replace my lens and now I'm worried I might have it in backward. How can I tell if the lens is in place incorrectly? By the way, my phone has never been dropped. It has been protected by an otter box since its purchase. My lens seemingly self-imploded. Just the strangest thing. Other than the lens, my camera doesn't have a scratch on it! Thank you for any help. Molly
Molly Azbell-Thompson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 77
Duração total: 152,839
