Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to remove or replace the NFC antenna and charging coil in your Samsung Galaxy S7.
This guide involves removing the rear glass cover. You will need replacement adhesive to reattach the back cover to the phone.
O que você precisa
Remove the eight 3.5 mm Phillips screws securing the NFC antenna and charging coil assembly.
4 outras pessoas executaram este guia.
9 comentários
this is perfect
Can you help me with videos ?
Does this also replace the charging port itself?
Hi Adam, this guide is not for replacing the charging port—the charging port is part of a separate assembly that requires further disassembly to remove.
