Ir para o conteúdo principal
Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement
O que você precisa
  1. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement, Rear Glass: passo 1, imagem 1 %32
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Apply a heated iOpener to a long edge of the phone for about two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 2, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 2, imagem 2 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 2, imagem 3 %32
    • When the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup and insert an opening pick under the rear glass.
    • The rear glass can break if you use too much force or attempt to pry with metal tools.
    • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  3. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 3, imagem 1 %32
    • Once you have the pick firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  4. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 4, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 4, imagem 2 %32
    • Slide the opening pick down along the side of the phone, separating the adhesive.
    • Go slowly so that the tip doesn't slip out of the seam. If sliding becomes difficult, reheat and reapply the iOpener.
    • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  5. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 5, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 5, imagem 2 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 5, imagem 3 %32
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick in each edge of the phone as you continue to the next to prevent the adhesive from resealing.
  6. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 6, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 6, imagem 2 %32
    • Lift the glass and remove it from the phone.
  7. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 7, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 7, imagem 2 %32
    • To reinstall the back cover with a custom-cut adhesive strip, follow this guide.
    • If you're cleaning the midframe surface with isopropyl alcohol, be careful not to get any alcohol on the wireless charging coil. The coil coating will break down if it contacts alcohol.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
  8. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement, NFC Antenna and Charging Coil Assembly: passo 8, imagem 1 %32
    • Remove the eight 3.5 mm Phillips screws securing the NFC antenna and charging coil assembly.
  9. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 9, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 9, imagem 2 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 9, imagem 3 %32
    • Insert the tip of a spudger into the small notch on the left side of the antenna assembly, and pry the assembly up and out of the frame.
    • Remove the antenna assembly.
  10. Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 10, imagem 1 %32 Samsung Galaxy S7 NFC Antenna and Charging Coil Assembly Replacement: passo 10, imagem 2 %32
    • Use the flat end of a spudger to lift the charging coil assembly out of the phone.
Conclusão
4 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
196.293 Reputação
Autoria de 416 guias
9 comentários
Can you help me with videos ?
amine.thrassers.35 - Responder
Does this also replace the charging port itself?
Adam Cornwell - Responder
Hi Adam, this guide is not for replacing the charging port—the charging port is part of a separate assembly that requires further disassembly to remove.
Adam O'Camb -
Wireless charging stopped working today on my S7 which is out of warranty. Do you know if this wil solve the problem or do I need to tackle it another way?
Jakob - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 35
Duração total: 9,347
