Introdução
A broken headphone jack can be a real drag! Instead of being that person on the bus who blasts music through their speakers, replace your headphone jack. Today we are gonna show you how to replace the headphone jack on your Galaxy S7.
O que você precisa
Instruções em vídeo
11 outras pessoas executaram este guia.
2 comentários
Attention Fixers! If you purchase this replacement headphone jack from iFixit, there’s a chance that yours comes with a black plastic clip that covers the headphone plug socket. You’ll need to remove this plastic clip first before attempting to install your new headphone jack.
Kadan Sharpe - Responder
Thank you Mr. Degnan for this! I worked. Don’t forget to take your time, try using adhesive remover and alcohol afterwards before putting cover on with new adhesive. Even you are firm but not forceful and go around with the picks several times, it will come off. Use the right screwdriver 00 size and don’t forget to disconnect battery! Test it before putting back in place.
Marco - Responder
