Ir para o conteúdo principal
Samsung Galaxy S7 Back Glass Replacement
O que você precisa
  1. Samsung Galaxy S7 Back Glass Replacement, Back glass: passo 1, imagem 1 %32
    • First get a heat gun or a hairdryer.
    • Heat up each side for about two minutes.
    • Once the adhesive has melted, stick in a pry tool and try to remove as much adhesive as possible, then use a suction cup to pry up on the back glass.
    • Carefully apply the new adhesive onto the phone.
    • Carefully place the new back glass onto the newly installed adhesive.
    • Let it dry before peeling off the protective seal.
Conclusão
How to fix your device followed the steps shown.
Andrew
Membro desde: 02/16/22
253 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 27
Últimos 30 dias: 106
Duração total: 3,263
