Ir para o conteúdo principal
Samsung Galaxy S7 Active Screen Replacement
O que você precisa
  1. Samsung Galaxy S7 Active Screen Replacement, Samsung Galaxy S7 Active Disassembly: passo 1, imagem 1 %32
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Screen Replacement: passo 2, imagem 1 %32
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Screen Replacement: passo 3, imagem 1 %32 Samsung Galaxy S7 Active Screen Replacement: passo 3, imagem 2 %32
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Screen Replacement: passo 4, imagem 1 %32
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, imagem 1 %32 Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, imagem 2 %32 Samsung Galaxy S7 Active Screen Replacement, Screen: passo 5, imagem 3 %32
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Samsung Galaxy S7 Active Screen Replacement: passo 6, imagem 1 %32 Samsung Galaxy S7 Active Screen Replacement: passo 6, imagem 2 %32 Samsung Galaxy S7 Active Screen Replacement: passo 6, imagem 3 %32
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
Conclusão
3 outras pessoas executaram este guia.
Erick Vazquez
Membro desde: 04/18/18
180 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro de Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
Membros da 4
Autoria de 15 guias
3 comentários
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Responder
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Responder
The instructions are excessively brief. The photos are insufficient to convey the details of this operation. Attempted and damaged my phone.
RAC - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 9,051
