Pular para o conteúdo principal
Introdução
This guide will teach you how to pry open your screen through the front side of the phone.
  1. Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Wedge the metal spudger in between the screen and the frame to begin separating them.
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Slide the metal spudger around the phone at least once. It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Lift the screen up with your hands.
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Use the tweezers to disconnect the screen from the phone by detaching the connection. Use the tweezers to disconnect the screen from the phone by detaching the connection. Use the tweezers to disconnect the screen from the phone by detaching the connection.
    • Use the tweezers to disconnect the screen from the phone by detaching the connection.
  6. Clean the rest of the adhesive left on the phone by scraping it off with a metal tool. Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin. Lightly proceed to clean the phone with that napkin.
    • Clean the rest of the adhesive left on the phone by scraping it off with a metal tool.
    • Apply rubbing alcohol on the adhesive to make sure phone is free of any adhesive. Do this by applying some rubbing alcohol onto a napkin.
    • Lightly proceed to clean the phone with that napkin.
Conclusão
Uma outra pessoa concluiu este guia.
Erick Vazquez
Membro desde: 18-04-2018
150 reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro de Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Membros
14 Guias de autoria
Do you know where i can find a replacement screen assembly, cant find one anywhere
Sam Ellis - Responder
I bought a digitizer with fog and polarizer and a new front glass, it came with the loca. What else do I need to make the complete LCD screen assembly?
Michael Shep - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 47
Últimos 30 dias: 282
Todo: 4,721
