Ir para o conteúdo principal
Samsung Galaxy S7 Active Disassembly
O que você precisa
  1. Samsung Galaxy S7 Active Disassembly, Samsung Galaxy S7 Active Disassembly: passo 1, imagem 1 %32
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Disassembly: passo 2, imagem 1 %32
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Disassembly: passo 3, imagem 1 %32 Samsung Galaxy S7 Active Disassembly: passo 3, imagem 2 %32
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Disassembly: passo 4, imagem 1 %32
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S18-G1, Livingston Spring 2018 Membro de Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
Membros da 4
Autoria de 15 guias
Um comentário
What about fixing the phone sure you can take it apart but what about fixing
Robert Ydstie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 4,328
