Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will demonstrate the steps necessary to replace a defective or damaged charging port daughterboard in the Samsung Galaxy S6. This component includes the audio jack, charging port, and side buttons.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
O que você precisa
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
75 outras pessoas executaram este guia.
9 comentários
I was able to follow these directions to replace the daughter-board on my Galaxy s6. I have *NO* technical experience. The real difficulty was with the products from iFixit - the gel pad didn’t melt the adhesive (I used a heat gun instead), the “guitar pics” were too flimsy & the screwdriver was RIDICULOUSLY small…I bought a mini Craftsman set that made ALL the difference.
My Samsung charging cable was melted, and after this I could not charge phone using micro usb. I’ve replaced Charging Port Daughterboard, but after this there is no Fast Charge. This option turned On in setup, but phone charging +4h.
Charger replaced, usb cable with 5 pins.
Any issue?
this for me was easy
