Introdução
Use this guide to access and fix the volume buttons of your phone.
O que você precisa
Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
Pry open the tray to get it out of the socket.
Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
Put a little pressure on the top, on the bottom, and on the sides of the phone to separate it from the plastic cover.
Uma outra pessoa concluiu este guia.
