Ir para o conteúdo principal
Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement
O que você precisa
  1. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Tools Required: passo 1, imagem 1 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Tools Required: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    iOpener
    $19.99
    Comprar
  2. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Applying Heat: passo 2, imagem 1 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Applying Heat: passo 2, imagem 2 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Applying Heat: passo 2, imagem 3 %32
    • Lay the iOpener pad across the phone. We'll start near the top since the bottom is cracked more.
    • Once the screen is heated up, use a suction cup and carefully pull up on the screen.
    • Gently work an opening pick into the gap between the screen and the phone.
    • Keep working around the edges by inserting more opening picks and applying more heat if needed.
  3. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Separating the Assembly: passo 3, imagem 1 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Separating the Assembly: passo 3, imagem 2 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Separating the Assembly: passo 3, imagem 3 %32
    • After creating enough of a gap between the screen and the phone, you will see that the LCD is held to the housing with very strong adhesive, a Samsung favorite.
    • As much as we tried, we could not prevent the already cracked screen from cracking further. It is possible to separate the screen assembly from the phone, but you'll need some heat and patience to slowly work it loose (proven by @cclarkcarroll, http://pixady.com/image/sm9/) These screens are EXTREMELY thin and fragile!
    • Gloves are advised as these thin LCDs can be nasty when they start to shatter.
    • The digitizer will likely separate from the LCD during removal so do not panic.
  4. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Disconnecting the Cracked Screen Assembly: passo 4, imagem 1 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Disconnecting the Cracked Screen Assembly: passo 4, imagem 2 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Disconnecting the Cracked Screen Assembly: passo 4, imagem 3 %32
    • Once the screen is separated from the phone, you will need to flip it vertically to gain access to the screen connector.
    • The connector is hidden under a plastic cover that can be popped off with a plastic pry tool.
    • After removing the cover, you can carefully remove the screen connector from the phone board.
  5. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Connecting the New Assembly: passo 5, imagem 1 %32 Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Connecting the New Assembly: passo 5, imagem 2 %32
    • After you've removed the cracked screen assembly, you will need to apply heat to the buttons to transplant them to the new assembly.
    • Remove the adhesive from the new assembly and carefully line up the buttons. They won't move easily once they're adhered.
    • Connect the new screen assembly to the board and install the plastic cover.
    • At this point, we recommend testing the phone before adhering the new screen into place.
  6. Samsung Galaxy S6 Active Digitizer/LCD Screen Assembly Replacement, Finishing Touches: passo 6, imagem 1 %32
    • After testing that the new screen assembly works properly, peel off the adhesive cover and carefully line up the screen.
    • Gently press around the screen to ensure a proper seal.
    • Enjoy your phone once more!
Conclusão
12 outras pessoas executaram este guia.
Corey Lehman
Membro desde: 02/12/17
673 Reputação
Autoria de 1 guia
Equipe
Alliance Computers Inc. Membro de Alliance Computers Inc.
Business
Membros da 16
Autoria de 2 guias
10 comentários
I run a cell phone repair business in the Midwest. Just did this repair without breaking the LCD using nothing more than heat, razorblades, and a playing card in less than 20 minutes. Your claim "it isn't possible without cracking the LCD" is false. Don't discourage other places like mine from trying it!
Christopher Carroll - Responder
Agreed, compared to other Samsung glass only repairs this one isn't too hard!
Julie Simpson -
That's awesome! To this day I have not been able to successfully separate the two without the LCD cracking slightly no matter how carefully I try. I guess I'm too worried about overheating the screen and causing damage. Great job!!
Corey Lehman -
I have updated the guide to inform shops that it is possible. Thank you Chris!
Corey Lehman -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 22,673
