Ir para o conteúdo principal
Samsung Galaxy S5 Sport Screen Replacement
O que você precisa
  1. Samsung Galaxy S5 Sport Screen Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy S5 Sport Screen Replacement, Battery: passo 1, imagem 2 %32 Samsung Galaxy S5 Sport Screen Replacement, Battery: passo 1, imagem 3 %32
    • Remove the back casing of the phone using the notch located at the top.
  2. Samsung Galaxy S5 Sport Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy S5 Sport Screen Replacement: passo 2, imagem 2 %32 Samsung Galaxy S5 Sport Screen Replacement: passo 2, imagem 3 %32
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Samsung Galaxy S5 Sport Screen Replacement, Screen: passo 3, imagem 1 %32 Samsung Galaxy S5 Sport Screen Replacement, Screen: passo 3, imagem 2 %32 Samsung Galaxy S5 Sport Screen Replacement, Screen: passo 3, imagem 3 %32
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  4. Samsung Galaxy S5 Sport Screen Replacement: passo 4, imagem 1 %32 Samsung Galaxy S5 Sport Screen Replacement: passo 4, imagem 2 %32
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-6, Leahy Spring 2016 Membro de USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 14
Duração total: 3,897
