Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will show you how to replace the back facing camera on this device. This guide requires removal of the screen, buttons, battery and protective plate. This may mean that to replace this camera, other parts of the device must be replaced as well.
  1. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top.
    • Remove the back casing of the phone using the notch located at the top.
  2. Lift up the battery using a plastic spudger or fingernail. Damaging the battery may result in physical injury and/or damage to the phone. Damaging the battery may result in physical injury and/or damage to the phone.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Turn on the heat gun. Make sure you don’t touch the metallic tip. You will burn yourself.
    • Turn on the heat gun.
    • Make sure you don’t touch the metallic tip. You will burn yourself.
    • Hold the heat gun roughly 6 inches away from the screen of the phone and slowly run the heat around the edge of the screen.
    • Keep at least 6 inches of distance from the screen. Keep moving the heat around to avoid warping the phone screen or internal parts.
  4. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  5. Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible. Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  6. The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger. In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  7. Remove the seventeen screws around the plate. Remove the seventeen screws around the plate. Remove the seventeen screws around the plate.
    • Remove the seventeen screws around the plate.
  8. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity.
    • Push the plate out by applying pressure to the battery cavity.
  9. Remove the back facing camera from the top of the phone by first disconnecting the ribbon cable from the connector with  a spudger or tweezers. Apply delicate pressure.
    • Remove the back facing camera from the top of the phone by first disconnecting the ribbon cable from the connector with a spudger or tweezers.
    • Apply delicate pressure.
Conclusão
Samantha McGilvray
Membro desde: 24-02-2016
148 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-6, Leahy Spring 2016 Membro de USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Membros
10 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 565
