Ir para o conteúdo principal
Samsung Galaxy S5 Mini SIM & SD card reader Replacement
O que você precisa
  1. Samsung Galaxy S5 Mini SIM & SD card reader Replacement, SIM & SD card reader: passo 1, imagem 1 %32
    • Remove back cover.
  2. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 2, imagem 1 %32
    • Remove battery. If you have SIM card and SD card in, remove them by the way.
  3. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 3, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 3, imagem 2 %32
    • Open this cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, imagem 2 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 4, imagem 3 %32
    • Heat the screen, cut the sticker under it and release the screen connector. Please be careful with the screen flex when sliding to cut the sticker.
  5. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 5, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 5, imagem 2 %32
    • Remove the LCD screen from rear case.
  6. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 6, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 6, imagem 2 %32
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 7, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 7, imagem 2 %32
    • Get loosen the touch keys from adhesive, and then push the mid-plate out from the middle housing.
  8. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 8, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 8, imagem 2 %32
    • Twist off these two screws and remove the whole motherboard assembly.
  9. Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, imagem 1 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, imagem 2 %32 Samsung Galaxy S5 Mini SIM & SD card reader Replacement: passo 9, imagem 3 %32
    • Release the connector,loose the assembly from adhesive and remove it finally.
Conclusão
3 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.822 Reputação
Autoria de 62 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 5,279
