Introdução
Use this guide to remove and replace the motherboard in a Samsung Galaxy S5 mini.
O que você precisa
Insert a fingernail or a plastic opening tool into the slot located above the power button.
Gently pull the panel off the back of the phone.
Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
Gently pry the battery away from the phone.
Ferramenta utilizada nesse passo:iOpener$19.99
Flip the phone and lay it on a flat surface so that the back is facing towards you.
Use a spudger or plastic opening tool to pry up the home button cable connector and disconnect it.
For reassembly, insert the home button cable connector through the open slot in the display assembly.
Use an iOpener to loosen the adhesive beneath the display.
Flip the phone over so it is lying on its back.
Insert a plastic opening tool or a plastic opening pick in the space between the screen and the frame and slide along the right side of the phone to loosen the adhesive.
Gently lift the display assembly away from the frame until there is a small gap and leave the first opening pick in the bottom right corner next to your home button.
Insert a second opening pick and slide it up to the top left corner of the phone by loosening the adhesive beneath the display.
Ferramenta utilizada nesse passo:Suction Handle$2.99
Use a suction handle to lift the display off of your phone. The home button cable connector should go with the display through a small gap in the mid frame. If it doesn't, use a tweezer to help a little.
Pull the display assembly away from the phone to remove it.
Remove the 12 4 mm Phillips screws #00 from the midframe.
Unscrew the 3 mm Phillips #00 screw holding the daughterboard to the motherboard assembly.
Use a plastic opening tool or spudger to pry the daughterboard from its socket.
Use tweezers to pull the cables connecting the daughterboard out from the motherboard.
Use a plastic opening tool or spudger to pry off the rear-facing camera from the motherboard.
Use a plastic opening tool or spudger to pry off the front-facing camera from the motherboard.
Use a plastic opening tool to pry up the SIM card assembly.
Peel the SIM card assembly away from the motherboard.
9 outras pessoas executaram este guia.
3 comentários
Is it possible that you can add pictures of the daughter board because i have a problem with my charging port shorting. and due to lack of finding the part on the internet i would like to see it (in good order) before trying to repair mine
Mine is s5 mini G800F and looks different im trying tho install new charger port and charger conector pins iv got the phone apart ok does any one no if the charger pins have to be soldered..
Hi, Yesterday I added a comment (although I can’t it on the site right now) I stated that the back on my S5 Mini was stuck on, not held by clips as you say in your S5 instructions. This was wrong. ''''
''''I wrongly thought my phone was an S5 Mini when in fact it’s an S6. I had forgotten that I had upgraded to the S6 some time ago and had not disposed of the S5 box etc. I will now rest my three remaining brain cells before attempting the repair of the S6.
Richard Kelsall - Responder
