Ir para o conteúdo principal
Samsung Galaxy S5 Mini Daughterboard Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy S5 Mini Daughterboard Replacement, Daughterboard: passo 1, imagem 1 %32
    • Remove the back cover.
    • Ther is an indent to insert your fingernail and unclip the back panel.
  2. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 2, imagem 1 %32
    • Remove the battery. If you have the SIM card and SD card in, remove them as well.
    • Whe re-assembling, make sure the battery contacts line up.
  3. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 3, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 3, imagem 2 %32
    • Open this small cover and release the home button flex connector.
  4. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 4, imagem 3 %32
    • Heat up the screen and cut the adhesive around the screen. Pry it up and release the LCD screen connector.
    • The connector is located at the top right of the screen, so lift it up or to the left.
  5. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 5, imagem 2 %32
    • Remove LCD screen.
  6. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 6, imagem 2 %32
    • Remove all the screws.
  7. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 7, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 7, imagem 2 %32
    • Remove mid-plate.
  8. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 8, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 8, imagem 2 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 8, imagem 3 %32
    • Remove screw, release USB board flex connector and antenna cable connectors.
  9. Samsung Galaxy S5 Mini Daughterboard Replacement: passo 9, imagem 1 %32 Samsung Galaxy S5 Mini Daughterboard Replacement: passo 9, imagem 2 %32
    • Remove the daughterboard and clean the signal cables from assembly. And you can replace the new USB charging board for Samsung Galaxy S5 Mini.
Conclusão
7 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.861 Reputação
Autoria de 62 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 5,937
