Ir para o conteúdo principal
Samsung Galaxy S5 Mini Battery Replacement
O que você precisa
  1. Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: passo 1, imagem 1 %32 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: passo 1, imagem 2 %32 Samsung Galaxy S5 Mini Battery Replacement, Rear Panel: passo 1, imagem 3 %32
    • Insert a fingernail or a plastic opening tool into the slot located above the power button.
    • Gently pull the panel off the back of the phone.
    • The plastic snaps will make a popping sound as they separate.
    Hi, Yesterday I added a comment (although I can’t it on the site right now) I stated that the back on my S5 Mini was stuck on, not held by clips as you say in your S5 instructions. This was wrong. ''''
    ''''I wrongly thought my phone was an S5 Mini when in fact it’s an S6. I had forgotten that I had upgraded to the S6 some time ago and had not disposed of the S5 box etc. I will now rest my three remaining brain cells before attempting the repair of the S6.
    Richard Kelsall - Responder
  2. Samsung Galaxy S5 Mini Battery Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy S5 Mini Battery Replacement, Battery: passo 2, imagem 2 %32 Samsung Galaxy S5 Mini Battery Replacement, Battery: passo 2, imagem 3 %32
    • Insert fingernail or plastic opening tool into the slot at the bottom of the battery.
    • Gently pry the battery away from the phone.
    • When replacing the battery, ensure the contacts are aligned and press lightly. The battery will appear to fit in multiple directions, so do not force it in.
Conclusão
7 outras pessoas executaram este guia.
Ethan Juhnke
Membro desde: 09/29/14
162 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-4, Forte Fall 2014 Membro de Cal Poly, Team 12-4, Forte Fall 2014
CPSU-FORTE-F14S12G4
Membros da 5
Autoria de 38 guias
2 comentários
that was so so hard!
dennysb de - Responder
But battery not charging properly
kapil jadhav - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 10,204
