Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the ten 3.4 mm Phillips #000 screws from the display side of the midframe.
Two 4.4 mm Phillips #000 screws near the USB port on the battery side of the phone
One 4.4 mm Phillips #000 screw
Gently run a plastic opening tool down along the left inner side of the interior frame to separate the three white plastic clips.
Gently pull the long sides of the silver bezel out away from the phone to separate the two halves of the midframe.
Continue on to the right side of the silver bezel, pulling away from the interior section of the midframe to separate the two halves.
Use a plastic opening tool to pry any remaining corners out of the silver bezel.
Carefully remove the interior midframe/motherboard assembly from the white inner midframe.
