Introdução
Use this guide to remove or replace the battery in your Samsung Galaxy S5.
If your battery is swollen, take appropriate precautions.
O que você precisa
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
83 outras pessoas executaram este guia.
10 comentários
Do I also need to remove the sim card? Or can I just put a new battery in?
Thanks am replacing glass as well...easy to get the battery and sim out.
