Ir para o conteúdo principal
Samsung Galaxy S5 Battery Replacement
O que você precisa
  1. Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy S5 Battery Replacement, Rear Case: passo 1, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy S5 Battery Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy S5 Battery Replacement, Battery: passo 2, imagem 2 %32 Samsung Galaxy S5 Battery Replacement, Battery: passo 2, imagem 3 %32
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery away from the phone.
Conclusão
87 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
474.477 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 23.292 guias
10Comentários do guia
This is too complicated :(
Jaydon - Responder
I replaced the battery in my phone because it drained fast, and drained completely in any temp below 50, I put the new battery In but when I try to turn it on the farthest I get is the screen that says "Samsung galaxy s5" help?
mw - Responder
Do I also need to remove the sim card? Or can I just put a new battery in?
nancysapone - Responder
Thanks am replacing glass as well...easy to get the battery and sim out.
rob taylor - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 208
Ao todo: 99,177
