Introdução
To replace the 16 megapixel rear-camera, follow the steps to remove all previous components required. Take full precaution when operating tools such as heat guns, as they can cause potential health hazards.
O que você precisa
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Use a Phillips 0 screwdriver to remove all 12 Phillips #0 screws.
7 outras pessoas executaram este guia.
6 comentários
Where did you purchase the replacement camera/lens?
Same here. I only need the lens cover.
On ebay sales
What if I'm just replacing the glass and not the entire camera?
Did you get an answer already? Or did you find a solution in the mean while? My cameraglass is also broken...
