Ir para o conteúdo principal
Samsung Galaxy S4 Mini Speaker Replacement
O que você precisa
  1. Samsung Galaxy S4 Mini Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Speaker Replacement: passo 2, imagem 1 %32
    • Remove the back cover of the cell phone using a plastic opening tool.
    The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
    Håvard Haugen - Responder
  3. Samsung Galaxy S4 Mini Speaker Replacement: passo 3, imagem 1 %32
    • Pry the battery out using a plastic opening tool.
    Vai s4 mini motherbotd paua jay
    atik.pgm - Responder
  4. Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: passo 4, imagem 1 %32 Samsung Galaxy S4 Mini Speaker Replacement, Sim Card and Memory Card: passo 4, imagem 2 %32
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. Samsung Galaxy S4 Mini Speaker Replacement, Grey Cover: passo 5, imagem 1 %32
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, imagem 1 %32 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, imagem 2 %32 Samsung Galaxy S4 Mini Speaker Replacement, Gray cover: passo 6, imagem 3 %32
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: passo 7, imagem 1 %32 Samsung Galaxy S4 Mini Speaker Replacement, Loud Speaker: passo 7, imagem 2 %32
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Samsung Galaxy S4 Mini Speaker Replacement, New Loud Speaker: passo 8, imagem 1 %32
    • Insert the new loud speaker
Conclusão
31 outras pessoas executaram este guia.
Luis Ojeda
Membro desde: 09/23/14
989 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-2, Blackwell Fall 2014 Membro de USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
Membros da 5
Autoria de 11 guias
3 comentários
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 13,743
