Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
If the device exhibits trouble playing sounds during calls, notifications, or the use of applications, it might be a good idea to replace the loud speaker on the rear of the phone.
  1. Press and hold the END key to power the phone down.
    • Press and hold the END key to power the phone down.
  2. Remove the back cover of the cell phone using a plastic opening tool.
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Pry the battery out using a plastic opening tool.
    • Pry the battery out using a plastic opening tool.
  4. Remove Sim Card using a tweezer or fingers Remove Memory Card using a tweezer or fingers
    • Remove Sim Card using a tweezer or fingers
    • Remove Memory Card using a tweezer or fingers
  5. In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
    • In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
  6. Then, use the plastic opening tool around the cellphone to open the plastic gray cover Exert the gray cover from the plate and screen would come out easily. Exert the gray cover from the plate and screen would come out easily.
    • Then, use the plastic opening tool around the cellphone to open the plastic gray cover
    • Exert the gray cover from the plate and screen would come out easily.
  7. Exert some pressure on the gray cover to separate the loud speaker from the plate. Exert some pressure on the gray cover to separate the loud speaker from the plate.
    • Exert some pressure on the gray cover to separate the loud speaker from the plate.
  8. Insert the new loud speaker
    • Insert the new loud speaker
Conclusão
30 outras pessoas concluíram este guia.
Luis Ojeda
Membro desde: 23/09/2014
965 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-2, Blackwell Fall 2014 Membro de USF Tampa, Team 9-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G2
5 Membros
10 Guias de autoria
my phone has sound!!!!!! thank you for the tech advice
Stevie Jackson - Responder
perfect. thankyou
rick bailey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 13,140
