Ir para o conteúdo principal
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
O que você precisa
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: passo 1, imagem 1 %32
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 2, imagem 1 %32
    • Remove the back cover of the cell phone using a plastic opening tool.
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 3, imagem 1 %32
    • Pry the battery out using a plastic opening tool.
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: passo 4, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: passo 5, imagem 1 %32
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: passo 6, imagem 1 %32
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 7, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 7, imagem 2 %32
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 8, imagem 1 %32
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 9, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 9, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 10, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 10, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 11, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 11, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 2 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 3 %32
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 13, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 13, imagem 2 %32
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Richard
Membro desde: 02/07/17
32.249 Reputação
Autoria de 11 guias
Equipe
EDU Team Membro de EDU Team
Staff
Membros da 7
Autoria de 753 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 5,509
