Ir para o conteúdo principal
Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]
O que você precisa
  1. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Battery: passo 1, imagem 1 %32
    • Press and hold the END key to power the phone down.
  2. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 2, imagem 1 %32
    • Remove the back cover of the cell phone using a plastic opening tool.
    The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
    Håvard Haugen - Responder
  3. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 3, imagem 1 %32
    • Pry the battery out using a plastic opening tool.
    Vai s4 mini motherbotd paua jay
    atik.pgm - Responder
  4. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: passo 4, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SIM Card: passo 4, imagem 2 %32
    • Using tweezers, remove the SIM card by sliding it towards the bottom of the device.
  5. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], SD Card: passo 5, imagem 1 %32
    • Using a nylon spudger, push through the hole at the top of the memory card holder to slide it out.
    Does “slide it out” refer to memory card holder or the memory card itself?
    Mikko Rantalainen - Responder
    Photo useless. Cannot see where “hole” is.
    Brian Gilkes - Responder
  6. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon], Motherboard [Verizon]: passo 6, imagem 1 %32
    • Remove the ten 4.0 mm screws on the back of the phone using the #00 Phillips screwdriver.
  7. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 7, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 7, imagem 2 %32
    • Starting at the USB port, slide a plastic opening tool around the perimeter of the phone between the rear housing and frame. As you work your way around the edge, you will feel the clips release.
    • Carefully separate the rear housing and the mid-frame to reveal the inside of the phone.
  8. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 8, imagem 1 %32
    • Use a pair of tweezers to lift the two charging assembly press fit connectors free.
  9. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 9, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 9, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the headphone jack press-fit connector up to release the ribbon cable.
    • This part might be different if your device is using duo SIM
  10. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 10, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 10, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the infrared sensor press-fit connector up to release the ribbon cable.
  11. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 11, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 11, imagem 2 %32
    • Use the flat end of a nylon spudger to lift the front-facing camera press-fit connector up to release the ribbon cable.
  12. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 2 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 12, imagem 3 %32
    • Gently lift the motherboard up and partially away from the device.
    • The digitizer ribbon cable is still attached to the underside of the motherboard.
  13. Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 13, imagem 1 %32 Samsung Galaxy S4 Mini Motherboard Replacement [Verizon]: passo 13, imagem 2 %32
    • Put the flat end of a nylon spudger under the lip of the digitizer press-fit connector and lift up to release the connector and free the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Richard
Membro desde: 02/07/17
29.913 Reputação
Autoria de 11 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.732 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 5,173
