Introdução
A guide to show how to replace the home button assembly on a Samsung Galaxy S4 mini
O que você precisa
Start by removing the back case, battery, sim card, and sd card.
Now remove the 10 screws using a #00 philips screwdriver.
After the ten screws are removed, proceed by separating the middle housing from the back housing using a opening tool such as a guitar pick or another separating tool.
Use a plastic pry tool to free the flex cable connections on the logic board.
Once all flex connections are freed then proceed to lift from the side that the power button is on. The displays flex cable is located on the other side of the logic board so use caution and don't lift to fast or with to much force.
With the board tilted at an angle take your plastic pry tool and free up the displays flex cable connection from the logic board.
Now all cables are disconnected and you can safely remove the logic board.
Once the adhesive is loosened slowly lift the screen starting torward the top of the display and make sure to slide the displays ribbon cable through the slot in the display housing.
Once you get to the bottom of the display you will need to also slide the flex cable through its slot in the displays housing as well.
Now that the display has been removed we can proceed to removing the home button flex cable assembly.
Use a plastic pry tool and first pry up the back button section. It is held in place with adhesive so you can use a little heat to loosen the adhesive if need be.
The back button is not adhered down and you can simply pop it out.
Last you need to pry up the section that the menu button resides in. It is held in place with adhesive as well.
Now the home button assembly if removed and you can proceed to install your new home button flex cable assembly. This can be done by using these directions in reverse order.
9 outras pessoas executaram este guia.
