Introdução
Use this guide to replace a microSD card in your Samsung Galaxy S4.
O que você precisa
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
28 outras pessoas executaram este guia.
Um comentário
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
