Pular para o conteúdo principal
Introdução
Use this guide to replace a microSD card in your Samsung Galaxy S4.
Peças
Nenhum componente especificado.
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    I snapped the back cover sorry m8
    Daniel Anishchenko - Responder
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above pic and found the divot and was able to take off the rear cover as per the “Step 1 rear cover” instructions.
    Terry Crawford, Jr. - Responder
  2. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  3. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Responder
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
  4. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the microSD card.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    I was able to remove the MicroSD Card as per the Step 3 MicroSD instructions with no problems.
Conclusão
28 outras pessoas concluíram este guia.
Sam Goldheart
Membro desde: 18-10-2012
385.687 reputação
544 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
105 Membros
9.264 Guias de autoria
If you use Micro SD card the you must know to How to Recover Memory Card
we are not going to use any app/softwares we only use CMD and 5 exclusive methods
http://www.gogorapid.com/how-to-recover-...
Ramal jayaratna - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 76
Todo: 84,360
