Introdução
Changing a full LCD module is expensive, here I explain step by step how to replace only the glass. That way you can savage the LCD and remove only the broken glass and separate it from the LCD
enjoy
O que você precisa
Vídeo de Apresentação
If your LCD and everything else works fine and your phone look like this picture, you can change the glass
not all the heatgun are the same, get on with variable temperature
not all the glues are the same. Get XFACTOR or Octopus brand are good.
if you get something like you see in the picture make sure the caps are green and not blue, Those chinese brands sometimes can be crappy, the red tube with blue caps is the crappiest
most of the replacement on ebay are fine, make sure it has the brand on it. There are some they are blank.
it has nice blades to help you to separate the lcd from the broken glass. It has all the tips needed in order to remove all the screws and other parts
just start moving the heatgun shooting heat all over the glass quickly and dont let it be over 100 degrees celsius or you will damage the LCD and it will turn gold, if that happen you will have to change the whole LCD module
start with the blade from the lower corner, with the blade slowly
i got all my videos in my youtube channel GabakUSA if you want to see the whole video. https://www.youtube.com/watch?v=wCeoVSVw...
lift the glass with the blade and put the card
keep heat and lift it up very slowly
flex is on the top be careful
it has to be like a mirror. Here as the picture shows
use a cotton to clean and the plastic tool
remove all screws
remove bezel
remove front face camera
remove screws from the logic board
unplug everything
leave lcd module alone
do it slowly and dont make bubbles
when you put the new glass slowly too. use your knife to put it down
i like this uv light instead of the sun
you can use sun as well but i dont recommend it
put logic board + frontal face camera
bezel back
put all the screws.
turn it on
enjoy!!
9 outras pessoas executaram este guia.
