Ir para o conteúdo principal
Samsung Galaxy S4 Front Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy S4 Front Facing Camera Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Front Facing Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 2, imagem 2 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: passo 3, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: passo 3, imagem 2 %32 Samsung Galaxy S4 Front Facing Camera Replacement, MicroSD Card: passo 3, imagem 3 %32
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Galaxy S4 Front Facing Camera Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement, Battery: passo 4, imagem 2 %32 Samsung Galaxy S4 Front Facing Camera Replacement, Battery: passo 4, imagem 3 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: passo 5, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: passo 5, imagem 2 %32 Samsung Galaxy S4 Front Facing Camera Replacement, SIM Card: passo 5, imagem 3 %32
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Samsung Galaxy S4 Front Facing Camera Replacement, Midframe: passo 6, imagem 1 %32
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. Samsung Galaxy S4 Front Facing Camera Replacement: passo 7, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 7, imagem 2 %32
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Samsung Galaxy S4 Front Facing Camera Replacement: passo 8, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 8, imagem 2 %32
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Front Facing Camera Replacement: passo 9, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 9, imagem 2 %32
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Front Facing Camera Replacement: passo 10, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 10, imagem 2 %32
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  11. Samsung Galaxy S4 Front Facing Camera Replacement: passo 11, imagem 1 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 11, imagem 2 %32 Samsung Galaxy S4 Front Facing Camera Replacement: passo 11, imagem 3 %32
    • Remove the midframe from the display assembly.
  12. Samsung Galaxy S4 Front Facing Camera Replacement, Front Facing Camera: passo 12, imagem 1 %32
    • Remove the upper display assembly bracket.
  13. Samsung Galaxy S4 Front Facing Camera Replacement: passo 13, imagem 1 %32
    • Using the flat end of a spudger, disconnect the front-facing camera cable connector.
  14. Samsung Galaxy S4 Front Facing Camera Replacement: passo 14, imagem 1 %32
    • Remove the front-facing camera.
Conclusão
66 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
463.236 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 16.253 guias
10 comentários
Hi my front camera is bright white all of a sudden... is it broken or am I I'm some sort of mode it's only the front facing cam. .
James - Responder
Any instructions for replacing the front speaker? I think I clogged it with glue when replacing the front glass.
Thanks!
Bill Carden - Responder
Great set of instructions! Pictures are very accurate and helpful! When it only take 5-10 mins to do something you have never tried before, you know the instructions were excellent! Thanks
laura - Responder
Excellent instructions. At step 12, the bracket is fragile and can easily ping off across the room so be careful. Thanks.
Ageingjedi - Responder
My front camera is a bright white also, even on video recording but you can still hear sound.
Cin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 27
Duração total: 65,792
