Introdução
i9500, i9505, i9506, i337, M919, I545, L720, R970
This procedure is similar for all of these models, but the Display Assemblay with Frame is not compatible. You must select the spare part by the model!!!
This video will help you, if you want to replace the front or rear / main camera, loudspeaker, earpiece, charging port dock board as well.
O que você precisa
Instruções em vídeo
32 outras pessoas executaram este guia.
4 comentários
Same for i9515 model?
Martynas Butkus - Responder
Hi. I have a Galaxy S4 (SCH-R970). This Model is CDMA and I want to take it to GSM. My question is: Can I change the Motherboard for one other Model i9500, i9505, i9506, i337? Thank you
M MCC - Responder
I have an I9500 that needs a new charge port. I put a new charge port in but it did not match the existing charge port that had a connection to what appears to be the front push button.(I assume because the push button doesn't work now)…do u know where I could get there correct charge port with the connector to the push button.
Dave Carlson - Responder
Great guide, thank you for posting. Display looks great, unfortunately it does not register any touch besides the soft keys. More troubleshooting here I come....
Sam - Responder
