Introdução
How to replace broken display assembly without middle frame.
Vídeo de Apresentação
  1. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button. Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone. Lift the rear case by the corner nearest the divot and remove it from the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the microSD card.
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward. Remove the battery from your phone. Remove the battery from your phone.
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click. After the click, release the card and it will pop out of its slot. Remove the SIM card.
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe. Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece.  Look for the seam between the two.
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  9. Continue prying around the corner of the phone. Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  10. Again, pry around the corner, to the power button side. Slide the opening tool along the seam.
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  11. Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly. At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  12. Remove the midframe from the display assembly. Remove the midframe from the display assembly. Remove the midframe from the display assembly.
    • Remove the midframe from the display assembly.
  13. Use the flat end of a spudger to disconnect the USB board connector. Disconnect the front-facing camera cable connector. Disconnect the earpiece speaker assembly cable connector.
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
  14. Disconnect the headphone jack assembly cable connector. Disconnect the display/digitizer cable connector. Disconnect the antenna cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  15. Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  16. Gently remove the motherboard. Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  17. Use a heat gun or hair dryer and warm the digitizer glass. If the glass is broken, put some scotch tape. Use an utility knife and make a room at upper side between the glass and the frame.
    • Use a heat gun or hair dryer and warm the digitizer glass.
    • If the glass is broken, put some scotch tape.
    • Use an utility knife and make a room at upper side between the glass and the frame.
    • Continue with the separating with a plastic tools (plastic spudger or something similar).
  18. Be very careful with the menu buttons flex cable. Be very careful with the menu buttons flex cable.
    • Be very careful with the menu buttons flex cable.
  19. Clean the frame from the old adhesive tape and install a new one. Preferably, use adhesive sticker which is made for the model.
    • Clean the frame from the old adhesive tape and install a new one.
    • Preferably, use adhesive sticker which is made for the model.
  20. When you install the new adhesive tape be careful, don't cover the holes for the front camera, light sensor, etc. Start with reassembling. Start with reassembling.
    • When you install the new adhesive tape be careful, don't cover the holes for the front camera, light sensor, etc.
    • Start with reassembling.
  21. That's all.
    • That's all.
    • Did you do it successfully?
Conclusão
25 outras pessoas concluíram este guia.
ZFix
Membro desde: 09-12-2013
167.315 Reputation
305 Guias de autoria
Master Techs Membro de Master Techs
Community
290 Membros
824 Guias de autoria
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 66
All Time: 28,019
