Ir para o conteúdo principal
Samsung Galaxy S4 Battery Replacement
O que você precisa
  1. Samsung Galaxy S4 Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S4 Battery Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy S4 Battery Replacement: passo 2, imagem 2 %32 Samsung Galaxy S4 Battery Replacement: passo 2, imagem 3 %32
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
    Where is the divot? Please let me know that
    James - Responder
    I purchased a blue plastic opening tool(AKA: Spudge) like the one used in the above Step 1 rear cover pic and found the divot and was able to take off the rear cover as per the “Step 2 “ instructions.
    Terry Crawford, Jr. - Responder
  3. Samsung Galaxy S4 Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy S4 Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy S4 Battery Replacement, Battery: passo 3, imagem 3 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
Conclusão
99 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.738 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
Um comentário
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
Mark Cosenza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 110
Duração total: 87,096
