Introdução
Use this guide to remove or replace the battery.
If your battery is swollen, take appropriate precautions.
O que você precisa
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
99 outras pessoas concluíram este guia.
Um comentário
A great super cheap, easy fix for an older phone. Can’t thank you enough. AAA+++
