Introdução
Use this guide to replace a defective motherboard in your Samsung Galaxy S4 Active.
O que você precisa
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Lift the rear case by the corner nearest the divot and remove it from the phone.
Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
Important! 4 of the screws are under the little "metallic" bolsters, one at each corner. These can be removed with a plastic opening tool.
Use the flat end of a plastic opening tool to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Disconnect the headphone jack assembly cable connector.
Disconnect the display/digitizer cable connector.
Disconnect the antenna cable connector.
22 outras pessoas executaram este guia.
4 comentários
Kiitos paljon
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Nota1000 fera + parabéns
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
