Ir para o conteúdo principal
Samsung Galaxy S4 Active Motherboard Replacement
O que você precisa
  1. Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S4 Active Motherboard Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Motherboard Replacement, MicroSD Card: passo 2, imagem 1 %32
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Motherboard Replacement, SIM Card: passo 4, imagem 1 %32
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Motherboard Replacement, Midframe: passo 5, imagem 1 %32
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
    Important! 4 of the screws are under the little "metallic" bolsters, one at each corner. These can be removed with a plastic opening tool.
    jeremiahmitchell87 - Responder
  6. Samsung Galaxy S4 Active Motherboard Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
  7. Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: passo 7, imagem 2 %32 Samsung Galaxy S4 Active Motherboard Replacement, Motherboard: passo 7, imagem 3 %32
    • Use the flat end of a plastic opening tool to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  8. Samsung Galaxy S4 Active Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  9. Samsung Galaxy S4 Active Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the motherboard.
Conclusão
22 outras pessoas executaram este guia.
Geoff Wacker
Membro desde: 09/30/13
89.934 Reputação
Autoria de 89 guias
4 comentários
I need a diagnosis. My device seems to be in a boot loop....any thought and suggestions would be helpful.
Justin Lujan - Responder
Nota1000 fera + parabéns
ricflavianoop - Responder
After the replacement of the motherboard, is there a procedure to Programm the old IMEI or will it imply a new IMEI?
Markus Elgrande - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 9,304
