O que você precisa
Use the plastic opening tool to take out the battery.
Remove SD card and SIM card.
Unscrew all screws.
Pry off midframe with plastic opening tool.
Unscrew screws holding daughterboard in place.
Carefully remove daughterboard with plastic opening tool.
The microphone is embedded in the daughterboard. This means the entire daughterboard must be replaced.
10 outras pessoas executaram este guia.
