Ir para o conteúdo principal
Samsung Galaxy S4 Active MicroSD Card Replacement
O que você precisa
  1. Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy S4 Active MicroSD Card Replacement, Rear Case: passo 1, imagem 2 %32
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active MicroSD Card Replacement, MicroSD Card: passo 2, imagem 1 %32
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
Conclusão
3 outras pessoas executaram este guia.
Geoff Wacker
Membro desde: 09/30/13
90.010 Reputação
Autoria de 89 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 14
Duração total: 1,488
