Ir para o conteúdo principal
Samsung Galaxy S21 Screen and Battery Assembly Replacement
O que você precisa
  1. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the SIM card tray: passo 1, imagem 3 %32
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the bottom edge: passo 2, imagem 1 %32
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display, internal battery, and plastic back cover are both susceptible to heat damage.
  3. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the bottom adhesive: passo 3, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the bottom adhesive: passo 3, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the bottom adhesive: passo 3, imagem 3 %32
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
    • Only insert the pick up to 5 mm, as you may damage internal components if you go further.
  4. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Slice the bottom adhesive: passo 4, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Slice the bottom adhesive: passo 4, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Slice the bottom adhesive: passo 4, imagem 3 %32
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick in to prevent the adhesive from resealing.
  5. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the left edge: passo 5, imagem 1 %32
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  6. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the left adhesive: passo 6, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the left adhesive: passo 6, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the left adhesive: passo 6, imagem 3 %32
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
  7. Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 7, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 7, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 7, imagem 3 %32
    • Slide an opening pick along the left edge towards the bottom left corner to cut the adhesive.
    • Don't cut past where the camera shell meets the back cover, as you risk cracking the plastic.
  8. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the right edge: passo 8, imagem 1 %32
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  9. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the right adhesive: passo 9, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the right adhesive: passo 9, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the right adhesive: passo 9, imagem 3 %32
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Only insert the pick up to 3 mm, as you may damage the secondary interconnect cable, which runs parallel to the right edge.
  10. Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 10, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 10, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 10, imagem 3 %32
    • Slide an opening pick back and forth along the back cover's right edge to cut the adhesive.
  11. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the corner adhesive: passo 11, imagem 3 %32
    • Rotate the right-edge opening pick around the top-right corner of the phone.
    • This procedure can be applied to each corner, except the top-left where the rear-facing camera is located.
  12. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the opening picks: passo 12, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the opening picks: passo 12, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the opening picks: passo 12, imagem 3 %32
    • Slide the top-most opening pick as close to the camera shell as possible.
    • Repeat for the left-edge pick.
  13. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the camera shell: passo 13, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the camera shell: passo 13, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the camera shell: passo 13, imagem 3 %32
    • Heat an iOpener and apply it to the camera shell for two minutes.
    • As you wait for the adhesive to loosen, note the following:
    • There's additional adhesive to the right of the camera that you need to cut through.
    • There's a plate on the back cover surrounding the phone's flash that the pick can get stuck on:
    • Angle the pick downward to avoid any damage.
  14. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the camera shell adhesive: passo 14, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the camera shell adhesive: passo 14, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Separate the camera shell adhesive: passo 14, imagem 3 %32
    • Rotate the back cover counterclockwise to create a gap between the camera shell and the frame.
    • Only insert the pick up to 5 mm to avoid scratching the camera.
    • Insert an opening pick in the gap.
    • If this method doesn't work, move to the next step for an alternative method; otherwise, skip the next step.
  15. Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 15, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 15, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 15, imagem 3 %32
    • Slide an opening pick between the camera shell and the frame to cut the adhesive.
    • There's a significant amount of adhesive securing the frame to the camera shell, so multiple rounds of heating may be needed.
  16. Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 16, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 16, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 16, imagem 3 %32
    • Line up the opening pick's tip with your phone's flash
    • Insert the pick slowly, making sure to avoid the flash's plate.
    • The plate's resistance can feel similar to adhesive. Angle the pick downward to keep the pick from sliding into the plate.
    • Slice the adhesive to the right of the camera.
  17. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the back cover: passo 17, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the back cover: passo 17, imagem 2 %32
    • Remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone until the back cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  18. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: passo 18, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the motherboard bracket: passo 18, imagem 2 %32
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3427.
  19. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unclip the motherboard bracket: passo 19, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unclip the motherboard bracket: passo 19, imagem 2 %32
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  20. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the battery: passo 20, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the battery: passo 20, imagem 2 %32
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: passo 21, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the wireless charging coil: passo 21, imagem 2 %32
    • While holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  22. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the loudspeaker: passo 22, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the loudspeaker: passo 22, imagem 2 %32
    • Use a Phillips screwdriver to remove the six 4 mm-long screws securing the loudspeaker to the frame.
  23. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the loudspeaker: passo 23, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the loudspeaker: passo 23, imagem 2 %32
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
  24. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the wireless charging coil: passo 24, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the wireless charging coil: passo 24, imagem 2 %32
    • Remove the wireless charging coil.
  25. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the primary interconnect cable: passo 25, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the primary interconnect cable: passo 25, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the primary interconnect cable's press connector.
  26. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the secondary interconnect cable: passo 26, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the secondary interconnect cable: passo 26, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the secondary interconnect cable's press connector.
  27. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the secondary/primary interconnect cables: passo 27, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the secondary/primary interconnect cables: passo 27, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the secondary/primary interconnect cables: passo 27, imagem 3 %32
    • Use a spudger to pry up and disconnect the secondary interconnect cable's press connector.
    • Repeat for the main interconnect cable's press connector.
  28. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the secondary/primary interconnect cables: passo 28, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the secondary/primary interconnect cables: passo 28, imagem 2 %32
    • Use tweezers or your fingers to remove both cables.
    • Set the cables aside. You'll reuse them during reassembly.
  29. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the daughterboard: passo 29, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the daughterboard: passo 29, imagem 2 %32
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the daughterboard to the frame.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3428.
  30. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the daughterboard: passo 30, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the daughterboard: passo 30, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the daughterboard: passo 30, imagem 3 %32
    • Use the point of a spudger to pry up the daughterboard.
    • Use your fingers to pull the daughterboard up and away from the bottom of the phone and remove it.
    • If you feel any resistance, the USB-C port could still be caught in its groove. Gently wiggle the daughterboard while pulling until it completely separates from the phone.
  31. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the earpiece speaker cable: passo 31, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the earpiece speaker cable: passo 31, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the earpiece speaker cable's press connector.
  32. Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 32, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement: passo 32, imagem 2 %32
    • Use a Phillips screwdriver to remove the seven 4 mm-long screws securing the earpiece speaker to the motherboard.
  33. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the earpiece speaker: passo 33, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the earpiece speaker: passo 33, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the earpiece speaker: passo 33, imagem 3 %32
    • Insert the point of a spudger into the gap between the right-most edge of the earpiece speaker and the phone.
    • Use the spudger to pry up and release the clips holding the earpiece speaker in place.
    • Use tweezers, or your fingers, to remove the earpiece speaker.
  34. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the display cable: passo 34, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the display cable: passo 34, imagem 2 %32
    • Use a spudger to pry up and disconnect the display cable's top press connector.
  35. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect left-edge cables: passo 35, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect left-edge cables: passo 35, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect left-edge cables: passo 35, imagem 3 %32
    • Use a spudger to pry up and disconnect the left 5G mmWave antenna cable's press connector.
    • Repeat for the power button cable's press connector.
  36. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the left-edge cables: passo 36, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the left-edge cables: passo 36, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the left-edge cables: passo 36, imagem 3 %32
    • Use tweezers, or your fingers, to bend the power button cable away from the phone.
    • Repeat for the left-edge 5G mmWave antenna cable.
    • Avoid folding or sharply bending the cables while repositioning them—doing so could tear the cables.
  37. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the front camera: passo 37, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the front camera: passo 37, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector.
  38. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the right-edge cables: passo 38, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the right-edge cables: passo 38, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the right-edge cables: passo 38, imagem 3 %32
    • Use a spudger to pry up and disconnect the orange press connector adjacent to the 5G mmWave antenna cable's press connector.
    • Repeat for the green 5G mmWave antenna cable's press connector.
  39. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the right-edge cables: passo 39, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the right-edge cables: passo 39, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Reposition the right-edge cables: passo 39, imagem 3 %32
    • Use tweezers or your fingers to bend both right edge cables away from the motherboard.
  40. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the motherboard/camera bracket: passo 40, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the motherboard/camera bracket: passo 40, imagem 2 %32
    • Use a Phillips screwdriver to remove the 4 mm-long screw securing the camera bracket and the motherboard to the frame.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screw with a new one labeled #3427.
  41. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the motherboard: passo 41, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the motherboard: passo 41, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the motherboard: passo 41, imagem 3 %32
    • Insert a spudger between the bottom-right edge of the motherboard and the frame.
    • Pry up with the spudger to release the clips securing the motherboard.
    • Use your fingers to remove the motherboard.
  42. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Heat the front camera: passo 42, imagem 1 %32
    • Apply a heated iOpener to the front camera for 90 seconds.
  43. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the front camera: passo 43, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the front camera: passo 43, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the front camera: passo 43, imagem 3 %32
    • Insert the point of a spudger into the gap between the frame and the front camera.
    • Pry up with the spudger to detach the front camera.
    • If you're having trouble separating the front camera from the frame, apply more heat; it may take a while for the adhesive to loosen.
    • Use tweezers, or your fingers, to remove the front camera.
  44. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Front camera reassembly instructions: passo 44, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Front camera reassembly instructions: passo 44, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Front camera reassembly instructions: passo 44, imagem 3 %32
    • During reassembly, follow these instructions to reinstall your front camera:
    • Peel off the front camera adhesive from its liner and apply the sticky end to the frame.
    • Use tweezers, or your fingers, to pull on the tab and expose the top layer of adhesive.
    • Insert the front camera and apply pressure to adhere it to the frame.
  45. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the 5G mmWave brackets: passo 45, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Unfasten the 5G mmWave brackets: passo 45, imagem 2 %32
    • Use a Phillips screwdriver to remove the three 3.5 mm-long screws securing the 5G mmWave antenna brackets to the frame.
  46. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: passo 46, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: passo 46, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the right 5G mmWave antenna: passo 46, imagem 3 %32
    • Use the point of a spudger to pry up on the right 5G mmWave antenna bracket's bottom screw tab.
    • Use tweezers, or your fingers, to remove the 5G mmWave antenna.
    • Set the antenna aside. You'll reuse it during reassembly.
  47. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: passo 47, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: passo 47, imagem 2 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the left 5G mmWave antenna: passo 47, imagem 3 %32
    • Use the point of a spudger to pry up on the left 5G mmWave antenna bracket's top edge.
  48. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the display cable: passo 48, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Disconnect the display cable: passo 48, imagem 2 %32
    • Use a spudger to pry up and disconnect the display cable's press connector near the bottom of the device.
  49. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the display cable: passo 49, imagem 1 %32 Samsung Galaxy S21 Screen and Battery Assembly Replacement, Remove the display cable: passo 49, imagem 2 %32
    • Use tweezers, or your fingers, to remove the display cable.
    • Set the cable aside. You'll reuse it during reassembly.
  50. Samsung Galaxy S21 Screen and Battery Assembly Replacement, Only the screen and battery assembly remains: passo 50, imagem 1 %32
    • You're now left with the screen and battery assembly.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Conclusão
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and follow the Samsung Self-Repair document (beginning page 10) to make sure your device is fully functional.
Download the Self Repair Assistant on your device and follow the Samsung Self-Repair document (beginning page 11) to perform a battery cycle reset.
8 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
93.813 Reputação
Autoria de 438 guias
Equipe
iFixit Membro de iFixit
Community
Membros da 136
Autoria de 15.131 guias
5 comentários
This was good overall. Thank you. If you can come up with a suggestion for gluing the front camera back in place properly, that would be great. The tiny Samsung/IFIXIT ring of tape seems ridiculous honestly.
Don Riggs - Responder
As a note, you need to remove the flex antenna in the top right corner from the old frame and move it over to the new frame, or you won't have signal. This applies even if you have a antenna in the new frame. Takes a tri-point screwdriver bit.
Vincent Bangrazi - Responder
Hi Vincent.
Thank you for your comment! The OEM replacement screen and battery assembly should come with the flex antenna pre-installed, and it should work properly after your repair. If your part didn't come with the antenna, please contact our customer support.
Alex Diaz-Kokaisl -
I had followed the steps and the phone is back up, however it keeps telling me now Incorrect pin even though I am putting in the correct one. Is there any I should double check is seated properly?
Vincent johnson - Responder
I followed the steps and my display is now working, however, the touch screen does not work so there is no way for me to swipe to unlock. it is also receiving phone calls but I can't swipe to answer or reject the call. any ideas?
Glenn Snow - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 148
Últimos 30 dias: 668
Duração total: 10,825
