Ir para o conteúdo principal
Samsung Galaxy S21 Screen Protector Replacement
O que você precisa
  1. Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: passo 1, imagem 1 %32 Samsung Galaxy S21 Screen Protector Replacement, Screen Protector: passo 1, imagem 2 %32
    • Remove the phone case and place phone on a flat, clean surface with the screen facing upward.
  2. Samsung Galaxy S21 Screen Protector Replacement: passo 2, imagem 1 %32
    • Remove the damaged screen protector carefully.
    • Usually this can be done with fingernails, but a plastic credit card or ID can make removal easier.
  3. Samsung Galaxy S21 Screen Protector Replacement: passo 3, imagem 1 %32 Samsung Galaxy S21 Screen Protector Replacement: passo 3, imagem 2 %32
    • Clean the phone screen off with an alcohol wipe to remove any fingerprints and dust from the screen.
  4. Samsung Galaxy S21 Screen Protector Replacement: passo 4, imagem 1 %32
    • Wipe and dry the phone screen with a microfiber cloth.
  5. Samsung Galaxy S21 Screen Protector Replacement: passo 5, imagem 1 %32 Samsung Galaxy S21 Screen Protector Replacement: passo 5, imagem 2 %32
    • Use stickers or tape to remove any dust particles that may have settled on the phone screen.
    • Have the new screen protector easily accessible during this step.
  6. Samsung Galaxy S21 Screen Protector Replacement: passo 6, imagem 1 %32 Samsung Galaxy S21 Screen Protector Replacement: passo 6, imagem 2 %32
    • Peel back the protective layer on the screen protector, and carefully line up the camera cutout with the front-facing camera, laying the top of the screen protector onto the phone screen.
  7. Samsung Galaxy S21 Screen Protector Replacement: passo 7, imagem 1 %32
    • Let the rest of the screen protector fall onto the screen, ensuring that the screen protector is square with the phone screen.
  8. Samsung Galaxy S21 Screen Protector Replacement: passo 8, imagem 1 %32
    • Press the screen protector into the screen with your fingers, starting in the middle of the screen and working outwards.
  9. Samsung Galaxy S21 Screen Protector Replacement: passo 9, imagem 1 %32
    • Work out any bubbles with the scraper/card by applying firm pressure into the screen protector and slowly sliding towards the nearest edge.
Conclusão
Now you have a brand-new screen protector! Enjoy the fresh look.
Philip
Membro desde: 02/22/24
169 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 58
Duração total: 79
