Ir para o conteúdo principal
Introdução
Follow this guide to remove and replace the earpiece speaker in the Galaxy S20.
While it is not completely necessary to remove the motherboard in order to remove the earpiece speaker, the repair is much easier with the motherboard out of the way.
You'll need replacement adhesive in order to complete this repair.
  1. Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band. If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press in firmly to eject the tray.
  2. Remove the SIM card tray. The SIM card will fall out of the tray easily.
    • Remove the SIM card tray.
    • The SIM card will fall out of the tray easily.
    • When you reinsert the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your phone's internal components.
  3. Unplug and power off your phone before you begin.
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible. If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  5. Slide the pick back and forth along the bottom edge to slice through the adhesive. Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel. Leave your opening pick in the seam to prevent the adhesive from resealing.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  6. Apply a heated iOpener to the left edge of the back cover for two minutes.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  7. Apply a suction cup to the back of the phone, as close to the center of the left edge as possible. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame. Insert the point of an opening pick into the gap.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  8. Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive. Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  9. Slide the pick all along the left edge of the phone to separate the back cover's adhesive. Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking. Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  10. Apply a heated iOpener to the right edge of the back cover for two minutes.
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  11. Apply a suction cup to the back of the phone, as close to the center of the right edge as possible. Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame. Insert the point of an opening pick into the gap.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  12. Slide the pick all along the right edge of the phone to separate the back cover's adhesive. Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing. As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  13. Apply a heated iOpener to the top edge of the back cover for two minutes.
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  14. The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover. Gradually slide the pick from the right edge of the device around the top right corner. Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  15. Lift the back cover slowly. Use opening picks to slice any remaining adhesive. Remove the back cover.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to replace the back cover perimeter adhesive before resealing your device.
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
  16. Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe. Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  17. Gently peel the wireless charging coil away from the device. Remove the wireless charging coil. The coil is connected to the rest of the device via spring contacts, so there is no need to disconnect any connectors.
    • Gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • The coil is connected to the rest of the device via spring contacts, so there is no need to disconnect any connectors.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  18. Use a spudger to pry up and disconnect the battery connector. When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  19. Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  20. Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place. Remove the loudspeaker and lower midframe. Remove the loudspeaker and lower midframe.
    • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
  21. Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage. To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  22. Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard. Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard. Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
  23. Gently peel up and remove the main and auxiliary flex cables. Gently peel up and remove the main and auxiliary flex cables. Gently peel up and remove the main and auxiliary flex cables.
    • Gently peel up and remove the main and auxiliary flex cables.
  24. Use a spudger to pry up and disconnect the main display flex cable from the motherboard. Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
    • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
  25. Gently peel up and bend the display flex cable out of the way of the motherboard and battery. Gently peel up and bend the display flex cable out of the way of the motherboard and battery.
    • Gently peel up and bend the display flex cable out of the way of the motherboard and battery.
  26. Use a Phillips #00 screwdriver to remove the four 4 mm-long screws securing the upper midframe.
    • Use a Phillips #00 screwdriver to remove the four 4 mm-long screws securing the upper midframe.
  27. Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place. Remove the upper midframe. Remove the upper midframe.
    • Insert the point of a spudger into the notch on the right side of the upper midframe and pry up to release the clips holding it into place.
    • Remove the upper midframe.
  28. Use a spudger to pry up and disconnect the side button flex cable from the motherboard. Use a pair of tweezers to bend the cable out of the way of the motherboard. Use a pair of tweezers to bend the cable out of the way of the motherboard.
    • Use a spudger to pry up and disconnect the side button flex cable from the motherboard.
    • Use a pair of tweezers to bend the cable out of the way of the motherboard.
  29. Pry up and disconnect the front facing camera flex cable from the motherboard. Bend the cable out of the way of the motherboard. Bend the cable out of the way of the motherboard.
    • Pry up and disconnect the front facing camera flex cable from the motherboard.
    • Bend the cable out of the way of the motherboard.
  30. Pry up and disconnect the front-facing sensor array cable from the motherboard. Bend the cable out of the way of the motherboard. Bend the cable out of the way of the motherboard.
    • Pry up and disconnect the front-facing sensor array cable from the motherboard.
  31. Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly.
    • Use a Phillips #00 screwdriver to remove the two screws securing the motherboard and camera assembly.
    • One 4 mm-long screw
    • One 3 mm-long screw
  32. Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body. Remove the motherboard assembly. Remove the motherboard assembly.
    • Insert the flat end of a spudger into the bottom left corner of the motherboard assembly and pry up to release it from the phone body.
    • Remove the motherboard assembly.
  33. Insert one point of  a pair of tweezers into the notch at the bottom right corner of the earpiece speaker. The earpiece speaker sits in a deep recess and is secured with adhesive. If you have trouble getting under it, apply a few drops of high concentration (over 90%) isopropyl alcohol to help soften the adhesive. Pry up to release the adhesive and remove the earpiece speaker.
    • Insert one point of a pair of tweezers into the notch at the bottom right corner of the earpiece speaker.
    • The earpiece speaker sits in a deep recess and is secured with adhesive. If you have trouble getting under it, apply a few drops of high concentration (over 90%) isopropyl alcohol to help soften the adhesive.
    • Pry up to release the adhesive and remove the earpiece speaker.
    • It is possible to reuse the speaker adhesive when installing a replacement speaker, but if you need to replace the adhesive, you can do so with a pre-cut adhesive sheet.
Conclusão
Uma outra pessoa concluiu este guia.
Tarun Thiruma
Membro desde: 20/11/2019
29.307 Reputação
133 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 64
Duração total: 1,159
